Page Index Toggle Pages: 1
Auxillary Belt (Read 900 times)
Salty
Ex Member
Auxillary Belt
19. Aug 2006 at 21:06
When changing the auxillary belt is it worthwhile changing the tensioner at the same time?
I'm going to do the cambelt soon and the aux belt looks like the rubber is beginning to crack so I was going to replace it at the same time.
Matchless
Omega Knight
Nottingham
Drives: The one at the end of the drive
Re: Auxillary Belt
Reply #1 - 19. Aug 2006 at 21:10
Check the tensioner pulley for play or roughness in the bearings, replace the pulley if bad but otherwise gently prise out the rubber seal and force a small amount of grease into the bearing then replace the seal.
Salty
Ex Member
Re: Auxillary Belt
Reply #2 - 19. Aug 2006 at 21:21
Matchless wrote on 19. Aug 2006 at 21:10:
I'll check that when I do the job. I'm just compiling a list of parts I'll need.
Robin Hood
Intermediate Member
Nottingham
Drives: Dirty Elite estate
Re: Auxillary Belt
Reply #3 - 19. Aug 2006 at 22:43
Just finished the Cambelt & Water Pump DVD which includes Mark testing and repacking the tensioner with grease, as described by Pete.
Over Active Poster
Bury Lancs
Drives: 1999 3.0 Elite auto/TDM
Re: Auxillary Belt
Reply #4 - 19. Aug 2006 at 23:35
SKF (or whoever) must have been tight with the grease. Had to do the same with mine cos it was as dry as a witches t*t too!
Salty
Ex Member
Re: Auxillary Belt
Reply #5 - 20. Aug 2006 at 07:33
Robin Hood wrote on 19. Aug 2006 at 22:43:
Any chance of a copy?
Robin Hood
Intermediate Member
Nottingham
Re: Auxillary Belt
Reply #6 - 20. Aug 2006 at 14:13
Salty wrote on 20. Aug 2006 at 07:33:
No problem, PM me with your address.
