Pages: 1 2
TV tuners (Read 1639 times)
Administrator
TBE has an MOT!
Brackley, Northants
Drives: 98 MV6, 03 Elite, 00 25, 89 ZX10
TV tuners
22. Sep 2008 at 13:43
I was out with my eldest brother the other day in his heap of poo X5, and it dawned on me...
...when the analogue TV gets turned off, will in car TVs die a death (obviously the analogue ones will) - will they make digital ones, ie is it possible to make a good enough aerial for in car TVs?
If you are going to kick a car, remember to wear appropriate footwear
Any posts are the result of my own views as a member of OOF, which may or may not be the same as my views as part of the Admin Team.
WWW
Administrator
TBE has an MOT!
Brackley, Northants
Re: TV tuners
Reply #1 - 22. Sep 2008 at 13:44
Oh, and no, I haven't turned into a chav - I have no desire for a TV in my car. It was a purely tech question...
WWW
Over Active Poster
London, W3
Drives: 2.2 CD (LPG'd) & BMW R1200 GS
Re: TV tuners
Reply #2 - 22. Sep 2008 at 13:47
says the man fitting a CID, which could be modified to have a VGA signal  Roll Eyes
Do you break V6's as often as TheBoy? Then you need tunnie's towing services, recovery costs are just the humiliation of being towed by 2/3's of an engine
Over Active Poster
London, W3
Re: TV tuners
Reply #3 - 22. Sep 2008 at 13:47
iic the ariels could be to blame too? As some old TV ariels don't have the capacticy to pickup digital signals?
Administrator
TBE has an MOT!
Brackley, Northants
Re: TV tuners
Reply #4 - 22. Sep 2008 at 13:48
tunnie wrote on 22. Sep 2008 at 13:47:
Thats irrelevent.  I am not having a TV in my car...
...FFS, the one in the house is troublesome enough Grin
WWW
Administrator
TBE has an MOT!
Brackley, Northants
Re: TV tuners
Reply #5 - 22. Sep 2008 at 13:50
All car aerials will be wideband anyway (all thats required for digital), the question I was posing was could a car aerial be powerful enough and selective enough?
WWW
Over Active Poster
London, W3
Re: TV tuners
Reply #6 - 22. Sep 2008 at 13:54
TheBoy wrote on 22. Sep 2008 at 13:50:
Seeing the signal qauilty of TV's in BMW 7 series, chances are low  Undecided
Martin Imber
Over Active Poster
LPG Omega V6 - Keyfobs
Rebuilt
Worcester
Drives: 2001 Omega 2.6CD LPG & 3.0 cams
Re: TV tuners
Reply #7 - 22. Sep 2008 at 14:06
When they turn the TXs up it will be fine, or use mobile DTV.
The other tuned 2.6. DIY LPG, towbar, upgrade ICE & Wing Spoiler, Air shocks, Eibach Pro Springs, Poly WB bushes, WIM setup, HID conversion, 3.0 cams, ported ect.
WWW
Martin Imber
Over Active Poster
Rebuilt
Worcester
Re: TV tuners
Reply #8 - 22. Sep 2008 at 14:06
Oh and put a DAT75 on the roof Grin Grin Grin Grin
WWW
Dave DND
Omega Baron
DND Services Ltd
Re: TV tuners
Reply #9 - 22. Sep 2008 at 14:11
Digital TV receivers for in car use have been on sale for a good few years now - (keep up !!  Roll Eyes )
Mixed feelings about them personally as the reception seems to be poorer than the analogue when going along. At least when the analogue signal dropped out the picture went fuzzy but was still tolerable, the digital one just goes blank or covers the screen in squares. Most annoying.
If you intend to put something in a car, don`t bother with a TV tuner at all, stick with DVD and if you want something for a caravan, or RV its cheaper these days to use a mobile sattellite receiver and dish, as they are now available for around the £100 mark.
Regards
Dave
Radio & Decoding Technician
DND Services Ltd
Paignton
01803-391680
dave@dndservices.co.uk
www.dndservices.co.uk
www.instant-radio-codes.com
WWW
Martin Imber
Over Active Poster
Rebuilt
Worcester
Re: TV tuners
Reply #10 - 22. Sep 2008 at 14:14
Dave DND wrote on 22. Sep 2008 at 14:11:
Never had a problem with Freeview - I use a PVR as well
WWW
Dave DND
Omega Baron
DND Services Ltd
Re: TV tuners
Reply #11 - 22. Sep 2008 at 14:17
Never thought of putting a freeview receiver in a car !!
I`ll have to try that out on the next customer !!
I wonder if the signal would be strong enough to use it?
Regards
Dave
DND Services Ltd
Paignton
01803-391680
WWW
Global Moderator
Admin Team
Alton, Hampshire
Drives: 3.2 MV6 (LPG), Westfield
Re: TV tuners
Reply #12 - 23. Sep 2008 at 14:46
Dave DND wrote on 22. Sep 2008 at 14:17:
I think at the moment it could be difficult to get a decent signal. It's marginal from a rooftop antenna with 15db gain or more in places, after all. Might improve as stated when the analogue carriers are removed from the equation and the transmitters can be driven harder on the digital carriers.
The other factor to consider is multipath. DTV was designed for static viewing. Using it in a car introdues a lot more multipath which will really screw up the bit error rate if, as I suspect, the equalisation in the receiver isn't up to coping with it.
That means watching it on the move would be a problem (why would you?) but also watching it when parked up in a city full of tall buildings or by a road with moving traffic. That's not going to be resolved by stronger signals. It's something the modulation and channel coding of the signal wasn't designed to cope with.
Dave DND
Omega Baron
DND Services Ltd
Re: TV tuners
Reply #13 - 23. Sep 2008 at 16:15
Why would you? I think something to do with keeping the little cherubs on the back seat quiet rather than the old fasioned method of communicating with them, playing I-Spy, or even the excellent method of keeping kids quiet in my day - thumping them very hard.
I take your point about the signals though -  Thumbs Up!
Amazing really, we tell the parents the signal will be crap, but still they won`t listen and keep paying us extortionate money to fit them, and then moan about it afterwards.
Regards
Dave
DND Services Ltd
Paignton
01803-391680
WWW
Global Moderator
Admin Team
Alton, Hampshire
Re: TV tuners
Reply #14 - 23. Sep 2008 at 16:31
OK. Point taken.  Embarrassed
Guess who hasn't got any "little cherubs"?  Wink
It's the problem we face with all these digital standards. As they are optimised to a greater extent, their range of application narrows to the point where you need a new standard for every application.
Maybe DVB-H or MediaFLO will eventually provide the answer. I must admit, I never appreciated the point of TV on a mobile phone, but to the back seat of a car on a long journey maybe it has its merits.
Pages: 1 2
