Pages: 1 ... 9 10 11 12 13 ... 17
Off with its head (s)!!! (Read 52476 times)
Martin Imber
Over Active Poster
LPG Omega V6 - Keyfobs
Rebuilt
Worcester
Drives: 2001 Omega 2.6CD LPG & 3.0 cams
Re: Off with its head (s)!!!
Reply #150 - 11. Mar 2009 at 22:35
Marks DTM Calib wrote on 11. Mar 2009 at 21:40:
Round files for the donky work and small flap wheels for the detail plus emery and a finger for the hard to get at bits.
Doesn't take long on alloy
There will be two 200bhp 2.6s on this forum soon Grin
The other tuned 2.6. DIY LPG, towbar, upgrade ICE & Wing Spoiler, Air shocks, Eibach Pro Springs, Poly WB bushes, WIM setup, HID conversion, 3.0 cams, ported ect.
WWW
Omega_Man
Ex Member
If all else fails, get
out the oxy!
Drives: Omega CDX 2.5 V6
Reply #151 - 11. Mar 2009 at 22:38
Martin Imber wrote on 11. Mar 2009 at 22:35:
And one 200bhp 2.5 when I get my hands on one Wink
Administrator
TBE has an MOT!
Brackley, Northants
Drives: 98 MV6, 03 Elite, 00 25, 89 ZX10
Reply #152 - 11. Mar 2009 at 22:44
Wonder if my 3.0l still produces anywhere near 200bhp after 11yrs/150k
If you are going to kick a car, remember to wear appropriate footwear
Any posts are the result of my own views as a member of OOF, which may or may not be the same as my views as part of the Admin Team.
WWW
chrisgixer
Omega King
Black ones are faster.
Wokingham
Drives: "Omega Black" 3.2 Elite. Thanks to Joshwyatt.
Reply #153 - 11. Mar 2009 at 23:27
hmmm, 3.2 next Mark? Roll Eyes
And by the way, is it likely all 2.6 and 3.2s will be effected?
« Last Edit: 12. Mar 2009 at 00:38 by chrisgixer »
HerefordElite
Omega Knight
Welcome to the Shire
Hereford
Drives: A6 Avant 2.5tdi Quattro Sport
Reply #154 - 12. Mar 2009 at 00:36
cem wrote on 11. Mar 2009 at 21:48:
Roll Eyes
This thread start to provoke me Grin
me too - can't wait for tomorrows instalment Wink
Nova SR, MKII Cav Sri130, MKII Astra GTE16v, Omega 3.0V6 Elite, Silver Cross Sleepover Classic
Administrator
Ex Member
Northern Hemisphere
Drives: Astra J, Mum Bus, Dexta Tractor, 108 DMU wip
Reply #155 - 12. Mar 2009 at 09:14
Likely to be a bit of valve lapping and assembly
Administrator
Ex Member
Northern Hemisphere
Reply #156 - 12. Mar 2009 at 22:14
Ok, all the valves lapped in nicely, the exhaust ones took a bit more doing (they often do due to running hotter) but, nothing more than a dab of fine paste required!
A shot of the seat following lapping, checking carefuly to ensure the valve seat and valve have nice solid consitent lapping marks!
A shot of the spring assembly, this consists of
1) A metal washer which sits between the base of the valve spring and the head (this MUST be fitted before the stem seals!)
2) The valve spring, these are the same on inlet and exhaust so no worries about mixing them up
3) The valve cap
4) A pair of multi ribbed collets
Next its time to fit the stem seals, I fit these with the valves in place as it makes it much easier to align and fit. A deep 10mm socket on an extension is perfect for pressing these into place.
Valve spring compressor fitted and the collets are going in. I use a small flat blade screwdriver that has been magnetised plus a dab of grease on the collet to make it stick nicely to the valve stem.
Re-fit the t-vents.....note there are two types of these. A version with a single drilling in the side which was used on the earlier pre 98 engines with the early oil pump and a later version with two drillings used with the later uprated oil pump. These effectively control the oil flow to the cam bearings and lifters.
A quick pic of the assembled head.
Thise shiney heat sheilds will give Mick something to think about when cleaning it!  Grin Grin
Welung666
Omega Lord
West Midlands
Drives: 99 2.5 saloon Tractor
Reply #157 - 12. Mar 2009 at 22:19
Get your picture etched onto the heat shields, that way he can think all the hard work you've done Thumbs Up!
Vehicle Movements, MOT's, tints and Repairs - PM for details.
CLICK HERE for instructions - how to Paperclip/Pedal test your car
Administrator
Ex Member
Northern Hemisphere
Reply #158 - 12. Mar 2009 at 22:22
Welung666 wrote on 12. Mar 2009 at 22:19:
You see that long number on the heatshields.....thats the bill (in pence!)  Grin Grin
Welung666
Omega Lord
West Midlands
Reply #159 - 12. Mar 2009 at 22:23
Grin Grin Grin
Administrator
Ex Member
Northern Hemisphere
Reply #160 - 12. Mar 2009 at 22:24
And for additional info, that colouring/staining in the head area is where its had an additive in it in the past (slick 50 is by far the worst for this!)
Administrator
Ex Member
Northern Hemisphere
Reply #161 - 12. Mar 2009 at 22:37
chrisgixer wrote on 11. Mar 2009 at 23:27:
Geff confirmed that both the 2.6 and 3.2 were affected for a short production run
Administrator
Ex Member
Northern Hemisphere
Reply #162 - 12. Mar 2009 at 22:40
I should add, if anybody wants me to photo any particular areas of the engine etc whilst its in bits then let me know and I will see what I can do!
My photobucket account is certainly filing up quick at the moment!
I am also hoping to try to build a head re-furb guide with some of the pics so feedback is appreciated
PaulW
Omega Knight
Come on you fiend!
53.25732, -2.52633
Drives: '51 Astra Eco4 & BMW R1200GSA
Reply #163 - 12. Mar 2009 at 23:49
Marks DTM Calib wrote on 12. Mar 2009 at 22:37:
Will Geff have ideas of what range of engine numbers they fell in??
Humbugs...
WWW PaulW paul.wollaston
Martin Imber
Over Active Poster
Rebuilt
Worcester
Reply #164 - 13. Mar 2009 at 00:41
Will I get a price for postage for the heads?
WWW
