Page Index Toggle Pages: 1
Minor interior illumination question (Read 789 times)
alexw
Newbie
Bognor Regis
Drives: P reg Omega 2.0 CDX auto
21. Aug 2011 at 12:51
Hi guys, thought as I'm slowly working my way through some of the other major issues with the car I'd start asking about some minor ones.
Firstly, the main light switch. I've pulled the unit out and checked the bulb, looks like it's working. However, the upper part of the unit (arrowed) doesn't light up. Silly question, but is it supposed to light up. I'd have assumed that it would but could be wrong. If it's supposed to light up, is there another bulb inside the unit that needs changing, or is it a sealed unit? The lower half does light up
The other issue is the gear selection display. The "P/R" and "1" aren't lit up, not got round to pulling it out yet to check but, again, I'd assume that all should light up. If so, are the bulbs changeable or not?
Just minor issues as I say, but I do like things to work if they're supposed to.
Any advice you can offer would be appreciated, thanks.
Global Moderator
Admin Team
Alton, Hampshire
Drives: 3.2 MV6 (LPG), Westfield
Re: Minor interior illumination question
Reply #1 - 21. Aug 2011 at 13:27
The headlight switch does light up but not with the headlights on. IIRC, it illuminates with the ignition on.
Looks like a couple of failed bulbs under the gear selector indicator but I haven't taken one apart so not sure what type of bulb or how many there are down there.
alexw
Newbie
Bognor Regis
Reply #2 - 21. Aug 2011 at 19:22
Kevin Wood wrote on 21. Aug 2011 at 13:27:
The top part of mine doesn't light up at all, only the lower part where the fog light switches are.
ajr3773
Junior Member
Newcastle Upon Tyne
Drives: Omega 3.0 V6 Elite Auto
Reply #3 - 21. Aug 2011 at 20:03
Replace the gear selector panel with a new or second hand unit. My original one never used to light up on D or P when i had the headlights turned on which ended up being a failure of the bulbs.
A second hand replacement from RobG sorted me out.
RobG
Omega Lord
I might have a link, pic
or part number for that
Bristol
Drives: 53 plate 2.2 CD auto
Reply #4 - 21. Aug 2011 at 20:22
ajr3773 wrote on 21. Aug 2011 at 20:03:
Got another here if OP requires Thumbs Up!
TC Holder Maxscan GS500 OBDII code reader/EML resetter available..
alexw
Newbie
Bognor Regis
Reply #5 - 22. Aug 2011 at 09:54
RobG wrote on 21. Aug 2011 at 20:22:
Thanks Rob, I could be interested in that. It's not high on my list at the moment but just in case, cost/condition and how would I pay you?
RobG
Omega Lord
Bristol
Reply #6 - 22. Aug 2011 at 10:03
alexw wrote on 22. Aug 2011 at 09:54:
PM sent Smiley
alexw
Newbie
Bognor Regis
Reply #7 - 22. Aug 2011 at 14:09
Well that should be the gear selector panel sorted, thanks Rob, anyone know about the light switch? Like I say, the lower half lights up but not the top part?
RobG
Omega Lord
Bristol
Reply #8 - 22. Aug 2011 at 15:17
alexw wrote on 22. Aug 2011 at 14:09:
Small soldered in led at the top
alexw
Newbie
Bognor Regis
Reply #9 - 22. Aug 2011 at 15:50
Again, thanks for that Rob. Did see 1 or 2 down the breakers when I was there. Next time I'm visiting I'll look for one.
robson
Intermediate Member
Nr Ashford Kent
Drives: omega V6 CD 2003
Reply #10 - 23. Aug 2011 at 08:57
Can the soldered in LED be replaced mine doesnt light up, Whilst on the subject of interior lights above the  small buttons on the centre console which direct the air flow of the blower there is a small grill does this have a bulb behind it.
